Gimbaly pro FPV kamery dostupné v obchodech
Video vysílače (VTX), FPV antény, FPV kamery, gimbaly a další FPV palubní elektromnika
Has thanked: 1136 times
Been thanked: 363 times
Hotové komerční řešení otáčení a naklápění FPV kamery (Pan/Tilt) pro DJI Air Unit.
https://fpvdogfight.com/products/motion ... ass-gimbal
Image Image Image
Ukázka funkce Pan/Tiltu s Headtrackingem:
Unboxing Pant/Tiltu dodávaného v rozsypu:
Parametry a popis:
Compact - fits under most RC plane canopies, needs only cylindrical space 40mm diameter, 50mm tall for full movement with the FPV camera; pan servo protruding beneath platform 23mm, platform dimension 36mm x 54mm (see pictures below), gimbal weighs 43 grams, air unit mount weighs 6 grams
Easy to install - use included screws and nuts to affix camera and platform to plane in minutes
Smooth/precise movement - includes 2x all-metal gear, digital, premium, high resolution, ball-bearing servos made specifically for Motionsic by Savox in Taiwan. Compare with Savox SH-0257MG $35/ea.
Check six for bandits - our custom servos allow the camera to pan 280° to see 360° (with camera field of view) and tilt up 85° (and down 85° with O3 Air Unit Camera).
Easy to adjust camera height/level to scale pilot eye position by adding/removing foam pads and adjusting the tightness of individual screws on corners of the platform.
Dampens vibration - foam pads also dampen vibrations from runway or road surfaces to make the visual experience pleasantly smooth.
UV resistant frame - impregnated with anti-UV polymer so gimbal frame stays robust with prolonged sun exposure.
Shock resistant - built to withstand minor plane crashes and keep on working!
Cena kolem 2100kč není na Pan/Tilt se servy nízká, ale co už je u digitálního FPV levné... ;)
Re: Pan/Tilty pro FPV kamery z obchodů
Přeposílám dva tipy od Rasila na kovové Pan/Tilt mechaniky.
První na Alliexpressu za cca 300kč
https://www.aliexpress.com/item/1005005666356097.html
Druhý také na Alliexpressu, za cenu něco lehce přes 300 Kč:
https://www.aliexpress.com/item/1005005912093851.html
AtomRC gimbal kompatibilní s DJI O3, Vista, nebo Walksnail Avatar. V jedno i dvouosém provedení, ke koupi zde:
https://www.banggood.com/ATOMRC-High-Re ... 97981.html
https://www.rotorama.cz/product/atomrc- ... -gimbal-2d
Image Image
Re: Pan/Tilty pro FPV kamery dostupné v obchodech
Strejda Číňan vymrštil další verzi Pan/Tiltu, tentokrát na míru modelu Swift 2100:
Xfly Model Servo Pan Tilt
https://www.aliexpress.com/item/1005007176550447.html
freeobrazky
Has thanked: 225 times
Been thanked: 203 times
Co jsem se koukal na gimbali GM1, 2,3, tak to vypadá že to má střídák a nikoliv klasické servo. Docela by mě zajímalo jestli by šlo třeba GM2 upravit aby se otáčela ve svislé ose a o 120 st. a náklon kamery prohodit na těch 60 st popřípadě nechat také na 120 st.
Má to dle info umět přímé PWM ovládání os, takže vynecháním vestavěného gyra by šlo mít relativně levný Gimbal pro FPV combat. Z té verze 2.
Ten GM2 má bohužel jako druhou pohyblivou osu tu, kterou v leteckých modelech vůbec nepotřebujeme. Abys ji změnil, musel bys to nejspíš celý úplně rozdělat a udělat si s tou elektronikou a motorkama svoji vlastní mechaniku, třeba na 3D tiskárně. Ty stříďáčky to ale má fakt rychlý, dovede to dělat rychlejší pohyby než běžná serva na stejně drahých PanTiltech pro DJI.
XF C-20T Standard Version Integrated Base Plate s přímou podporou pro DJI O3 a Walksnail Avatar přes UART rozhraní:
https://www.banggood.com/cs/XF-C-20T-Gi ... 17381.html
Specifikace:
Rozměry: 50x46,5x53 mm
Hmotnost: 46g
Pracovní napětí: 7-26V DC
Spotřeba energie: 1,5W (Statická)/14W (Špičková)
Metoda montáže: Stojatá/Obrácená instalace
Kompatibilita kamery: 19mm široká FPV kamera
Řídicí rozhraní: PWM/UART
Ovládání hlavového sledování: Podporuje
Přesnost stabilizace: ±0,005°
Ovladatelný rozsah rotace: pitch:-105°~+145°; Yaw:+165°
Maximální rychlost ovládání: pitch: ±1500°/s; Yaw:±1500°/s
SkyGadgets Pan/Tilt od polského konstruktéra Yurii Soldaka:
https://www.etsy.com/listing/1572644964 ... 1572644964
Return to “FPV vysílače, FPV kamery, FPV antény”
