FPV Air Combat - pravidla
Vzduščný souboj leteckých modelů pomocí IR combat modulů za doprovodu vizuálních a zvukových efektů. Tato kategorie má za cíl popularizovat letecké souboje z pohledu pilota, tak jak je viděli skuteční stíhací piloti, z kokpitu svého stroje.
Has thanked: 1146 times
Been thanked: 367 times
U příležitosti konání dalšího FPV Air Combat campu byla konečně specifikována soutěžní pravidla pro FPV Air Combat.
Zde je jejich originální znění:
Regulations of competitions and classes of flying models
1. Basics
1.1 Basic rules
All EU rules for UAVs and their R/C equipment must be followed with the changes given in these regulations. The
competitor is personally responsible for the flying model used in the competition and any personal and material
damage it may cause. The competitor's RC insurance is required (providing the policy number on request), the
obligation to register the pilot and the model obliges the pilot.
The organizers of the competition and the main judge of the competition are responsible for ensuring the safety of the
competitors and the audience during the competition, compliance with the provisions of the above regulations,
control of the frequency of the transmitters during the competition and the discipline and sporting nature of the
competitors' competition.
1.2 Safety
Safety always has the highest priority. Any behavior or incident considered by the main judge or competition
organizers to be dangerous may result in the immediate disqualification of the competitor from the event. Each
competitor may be asked to make a test flight to prove that they are able to fly a model aircraft made in accordance
with the national regulations.
2. Competition place
The choice of the place of the competition belongs to the organizer.
It is recommended that the area intended for the competition should not be smaller than 200 x 100 m and the flight
area, calculated in a radius from the place of take-off, is clear of trees or buildings at a distance greater than 100m
2.1 Zoning
The diagram below shows a typical suggested flight area layout for an FPV combat competition. The safety line is the
boundary of the flight area that must not be exceeded during the competition and is intended to keep the models at a
safe distance from the line of pilots and spectators
The safety line is of a contractual nature and should be marked with a white and red tape in the competition area, and
in the airspace it is understood as a half-plane perpendicular to the flight area.
The organizer is responsible for the control of the safety line (flight zone), which applies to all pilots from the opening
until the end of the competition. The organizer should leave as much distance as possible between the flight area and
the spectators. Suggested distances are given in the diagram below:
—--------------safety line 0m----------------------
---------------- pilot line5 m -----------------------
------------ spectator zone 10 - 15 m -----------
Event host can make changes in flying area according to local circumstances and it will be host’s responsibility to
guarantee that all participants are informed of eventual changes
2.2.1 Flight Zone
The flight zone is always ahead of the safety line. This is an area where temporary landings are allowed during
combat. Its dimensions are determined by the organizer depending on the area where the competition is held.
Any model that lands outside the landing zone cannot be picked up during combat or while other models are
airborne. Only models landing in this zone are allowed to be picked up during combat and take off again.
2.2.2 Landing field
A rectangular area 50 x 40 m (counting from the safety line) in the flight zone, marked by the Organizer with white
and red tape.
2.2.4 Safety line
The safety line runs parallel to the pilots line at a distance of 5 meters. The model cannot fly closer to the pilots than
indicated by this line. Any model that crosses this line is subject to a penalty and disqualification rules. This point
applies at all times from the opening of the competition to the official end. This applies to all flights (combat, test,
demonstration), all models in any case.
2.2.5 Pilots line + possible Starting Boxes
All pilots and helpers should start from behind this line. The line is located 5 m behind the line safety. Starting boxes
should provide a distance of 3-5 meters between pilots.
2.3. Audience
The audience should stay at a safe distance, not less than 10 m, behind a safety line or be protected by net-type
safeguards. The area protected by the net is defined as the area starting at the net to a distance equal to its height, i.e.:
for a 3 m high net, the safe area is up to 3 meters behind the net.
2.4 First aid
A first aid point should be marked at the competition site. At this point there should be a first aid kit available at any
time in case of an accident.
3. Models and Equipment depending on the class
3.1 Model
The material from which the model is made is all kinds of foam types: EPP, polystyrene, styrodur, depron. It is not
allowed to use any hard materials such as carbon, glass, wood, etc. to reinforce the leading edges of the wing and
stabilizers. The first rod reinforcing wings and empennage must be moved 10 mm from the leading edge. The model
must be entirely made of "soft" material.
It is allowed to strengthen the wing leading edge with a foil or foil tape reinforced with fiber.
3.1.1 Model in the Basic Combat class (RAPTUS)
https://www.fpv-combat.com/download/raptus/
The only model allowed in the Basic Combat Class is the RaptusS flying wing, made of "soft" material - e.g. EPP,
Depron, Styrofoam, Styrodur etc.
Wingspan 700mm and length 640mm, propeller size max 6 inches , Li-po battery 2-4S, max take-off weight 900g
Must install 2 paper ribbons - around 10mm wide - 5m long
3.1.2 Model in the Open Combat Class
Any model of aircraft or flying wing
- Weight: up to 3000g, (can be adjusted by host to meet local law)
- Motor: brushless or brushed motor
- Material: Styrofoam, Styrodur and the like.
3.2 Installation of the power supply
Each model participating in the competition must be able to quickly disconnect the battery from the ESC without the
use of tools or disassembly of the model in the event of a breakdown or fire.
Each competitor is required to have at least 2 batteries.
3.3 Propellers
Propellers of any type - commercially available, matched to class
- Basic Combat Class: max 6 inches
- Open Combat Class: no limit
3.4 Head protection
Each competitor and each person in front of the spectator line is obliged to wear and use a head protection.
3.5 Radio and FPV equipment (video)
Each competitor should check the range (operation) of his RC equipment before the competition. The competitor is
responsible for the proper operation of his RC equipment.
Activation of Video Transmitters (both analog and digital) is forbidden during official flying sessions for all the pilots
that are not participating in the match. Penalty for acting against this rule will be -50 Points
Judge/organizer will communicate the moment when pilots of the upcoming flying session can turn on their VTX.
The same announcement indicates that other pilots must keep OFF their VTX until the “end of the match”
announcement.
During flying LOS sessions such as categories ESA-WWI and ESA-WWII it is allowed to turn on VTX for testing
purposes.
It is the responsibility of each pilot to communicate to others that he is going to power on his system and in any case
it is not guaranteed that the assigned frequency will be free or reserved.
Activation of Video FPV transmitters is only allowed during times announced by the judge/organizer so as not to
disturb the vision of pilots with aircraft in the air. Both analog and digital video links are allowed. The maximum
transmitting power must be according to the actual local regulamentation.
The organizer assigns the video channels to the Players
3.6 FPV Combat equipment
General:
- lives, ammos, shooting rate, defense level, shooting power will be set by host remotely for each match
- The HC-12 module (433MHz) shall be removable
- The connection of the FPV-Combat Board and HC-12 module must be realized using female or male Servo Style
Connector (pitch 2.54)
FPV-Combat Hardware & Firmware
- The latest firmware has to be installed before the Combat Camp to save time at the event itself for FIGHTING!
- Please note! The related hardware-mod has to be applied.
Basic Combat Class:
- 1 Gun max
- 2 Sensors, one on each wing tip facing outwards according to latest model build plans
- 433Mhz HC12 telemetry module
- Combat Board must be mounted accessible and visible for inspection
Open Combat Class:
- 2 Guns max
- 2 Sensors, placed to allow maximum coverage (judges will check setup)
4. Competitions
4.1 Round structure
A round is the execution of exactly one fight by each pilot.
Number rounds that will be played in a given competition should be determined before the competition. It is
recommended to run at least 3-5 rounds.
The competition ends with the final, which is a consequence after all the announced rounds have been completed and
the best players have been tallied and selected. He/She meets in the final four the pilots who scored the most points
during the rounds. The pilot who has the highest sum of points counted from individual rounds together with the
achievements of the final fight wins the competition.
4.2 Scoring
Points will be assigned in the following way:
- 1 Successful Hit = 5 Points
- 1 Received Damage = -1 Point
- Bonus for no damage at the end of the session = 10 Points
4.3 Fights
The fight is understood as a sports competition of competitors (pilots) using their models. Each fight is divided into
three parts: preparation, readiness, flight.
4.3.1 Preparation
The length of the preparation time is determined by the organizer, five minutes is recommended. It is signaled by the
main referee announcing the preparation for the next fight.
Test flights may be performed during this part. 30 seconds before the end of the preparation time, the head judge
announces "30 seconds to start" or "Ready" which means the time to be ready
4.3.2 Getting Ready
The readiness takes place immediately after the preparation time and is announced by the head referee with a call.
During standby, all pilots and helpers should be on the standby line. The standby time varies depending on the
referee's decision.
4.3.3 Flight
The flight part begins when the chief judge gives one long signal (whistle or verbal command "start"). Pilots and
helpers can run to their planes and take off. The flight part ends when the chief judge gives another long signal
(whistle or verbal command). The pilots must now end combat and land when they decide they can. As soon as the
last model lands, another preparation time may be announced.
4.3 Observers
Each player must have an observer. Only one observer and a pilot per model may be in the line of pilots during the
flight (helmet mandatory).
The observer must be ready to help in case of loss of control, loss of video link or other technical problems etc…
4.4 Start
Participation of the competitor's helper in the start of the model is allowed (hand throw).
Each competitor after the start must go back to the pilots' line so as not to obscure the flight area of other
competitors. In the case of model capotage starting from the wheels, entering the flight zone and re-setting the model
for take-off is possible only after the start of other competitors
The Main Judge will provide the Start signal
- models are not allowed to take off before the “START” signal (penality: forced to land and take off again)
- The “START” signal also start timer(5 Minutes) and automatically arms the “FPV Combat”for all players
- Basic Combat Class can take off from provided ramps(but is not mandatory)
- Provided Ramps will have 2 rails with 21cm distance - 120cm length and 30°angle upwards
- Open Class can take off as they want.
4.5 Flight time
Maximum flight time is 5 min = 300s, the model setup must allow for a flight of this length
4.6 Restart in combat
There is no maximum number of starts per fight. When a pilot wants to take a model from the flying area (during a
fight) he must have permission from the chief judge. The chief judge alerts the pilots and makes sure they are warned
of the situation. The re-start must be made from the place where the first start took place, i.e. a return to the line of
pilots is required.
4.7 Model change
Only one model can be used per battle. The new model can be used in the next battle.
4.8 Crossing the safety line
Crossing the safety line is understood as crossing the designated safety zone with the model when the model is in the
air or when it is moving on the ground.
After the violation, the pilot receives -25 penalty points, after the second line violation must land immediately, he
cannot continue the competition - disqualification occurs.
4.9 Collisions
There are no penalty points for collisions or model loss.
4.10 The principle of non-involvement (avoiding combat)
If a pilot remains out of combat for more than 30 seconds, he should be warned by the main judge. A pilot who, after
the first warning, tells the judge that he has technical problems should immediately attempt to land his model in a
place that is safe for the competitors and spectators.
4.11 Draw
If after the final battle the pilots have an equal number of points, the pilot who scored more points in the final itself
wins. If these scores are equal, the pilot with the highest number of points during one of the fights in that competition
wins.
4.12 Video Frequencies / Bandwidth / Power
Standard Videoband is Raceband and DJI
All users must be able to set their transmitters in Raceband or DJI range!
DJI users have to set their system to 25 MBIT
The used channels will be:
The assigned channels will be displayed at the Rooster board.
- CH 1: RB-5658 Mhz / DJI 5660 Mhz
- CH 3: RB-5735 Mhz / DJI 5735 Mhz
- CH 5: RB-5843 Mhz / DJI 5839 Mhz (not to be used by Analog Players)
- CH 7: RB-5880 Mhz / DJI 5914 Mhz
The competitor must be prepared to change the frequency of his video transmitter.
In the event of a channel collision during the final, the player with fewer points should change the frequency.
Additional time must be given to the competitor for this substitution. Also preparation time for the final fight cannot
be enabled until this change is made. The competitor is responsible for selecting the channel so that there are no
channel collisions after the change.
- 50 point for turning on VTX during official fights
- 25 points for wrong VTX CH selected when moving to starting area
4.13 Deterioration/interference/complaint
If the weather or other conditions during the competition deteriorate, or the participating competitors complain
about the weather or other conditions to the organizer, the organizer should hold a vote for the majority of pilots to
decide whether the competition is to be postponed, canceled and how to treat previous results
5. Judges
5.1 Main Judge
The main judge is responsible for checking the weight of the models and timing during the round. The main referee is
obliged to observe the entire fight and in the absence of a line judge, to check the safety zone. The referee is also
responsible for keeping the competitors in front of the safety line when the planes are in the air.
Cheating or attempted cheating shall result in disqualification of the competitor. The referee's decision should be
based on the vote of the other players.
5.2 Safety judge
The safety judge is primarily responsible for safety at the competition. This judge has a higher rank than the head
judge when it comes to safety. The safety referee should warn about the dangers during the fights. He should be
positioned so that he can clearly see crossings of the safety line. He is also responsible for ensuring that no person
stays without a helmet outside the zone protected by the net or closer to the safety line than the designated distance
at the competition
5.3 Pilot observer
The pilot's judge is to record the points and flight time on the pilot's card. He is also responsible for registering the
crossing of the safety line (together with the safety judge), determination of non-engagement in combat,
determination of landing in the landing area for models.
The pilot's judge is also responsible for delivering the competitor's card to the main judge and for its correct filling
and signatures.
Re: FPV Air Combat - pravidla
Já jsem byl některými body poněkud překvapen, ale rozumím, že nejde zavděčit se všem a nějakými pravidly se u kompetitivní disciplíny jakou FPV Air Combat je, začít musí.
Mně osobně se na zveřejněných pravidlech nelíbí dvě věci:
1) Rozvržení modelů do pouhých dvou kategorií tak, jak se to provedlo, tedy Basic (což je zároveň pouze jediný konkrétní model RuptuS, do 900g) a Open (tedy vše ostatní do 3Kg). Čekal jsem totiž, že jednou z kategorií bude i SUB250, už jen proto, že se FPV Air Combat na “dvěstěpadesátkách” také docela úspěšně létá a řada FPV combat modulu MICRO je na SUB250 přímo jako dělaná. Teď by se tedy teoreticky mohly v jednom zápase proti sobě postavit SUB250 a 3kg modely, to mi přijde poněkud zvláštní.
2) Ještě víc jsem předpokládal, že se jasně oddělí kategorie FPV analog a FPV digital, aby se nemohly potkat v jednom zápase. Protože soutěžící s analogovými FPV brýlemi je poměrně dramaticky handicapován velice nízkým rozlišením a nízkou kvalitou obrazu, obzvláště při povoleném výkonu VTX 25mW. To potvrdí každý, kdo tu možnost srovnání analog vs digital FPV na 25mW měl.
Naopak oceňuji, že se vyčlenila jedna kategorie pro jeden jediný konkrétní model (RuptuS), kde o výsledku bude rozhodovat hlavně dovednost pilotů a ne rozdílnost konstrukcí jejich modelů. Předpokládám ale, že se tato pravidla ještě budou později dolaďovat, tak si to třeba sedne ;)
Zde jsou aktualizovaná pravidla pro FPV Air Combat na rok 2024:
https://www.fpv-combat.com/3d-flip-book/2231/
Soutěžní pravidla z roku 2024 platí i pro ročník 2025. Doplňuji pouze stručný překlad těchto pravidel, originální znění je zde:
1. Základy
1.1 Základní pravidla
Všechna pravidla EU pro UAV a jejich R/C vybavení musí být dodržována s výjimkami uvedenými v těchto předpisech. Soutěžící je osobně odpovědný za model použitý v soutěži a za jakoukoli osobní nebo materiální škodu, kterou může způsobit. Je vyžadováno RC pojištění soutěžícího (s uvedením čísla pojistky na požádání) a povinnost registrace pilota i modelu.
Organizátoři soutěže a hlavní rozhodčí odpovídají za bezpečnost soutěžících a diváků, dodržování ustanovení předpisů, kontrolu frekvencí vysílačů a zajištění disciplíny a sportovního chování soutěžících.
1.2 Bezpečnost
Bezpečnost má vždy nejvyšší prioritu. Jakékoli chování nebo incident, které hlavní rozhodčí nebo organizátoři považují za nebezpečné, mohou vést k okamžité diskvalifikaci soutěžícího. Každý soutěžící může být požádán, aby předvedl zkušební let k prokázání schopnosti létat s modelem v souladu s národními předpisy.
2. Místo konání soutěže
Volba místa soutěže je na organizátorovi.
Doporučuje se, aby plocha určená pro soutěž nebyla menší než 200 x 100 m a letová zóna, počítaná v okruhu od místa vzletu, byla bez stromů nebo budov ve vzdálenosti větší než 100 m.
2.1 Rozvržení zóny
Letová zóna musí být oddělena bezpečnostní linií, která musí být označena červenobílou páskou. Organizátor je odpovědný za kontrolu této zóny a její dodržování během celé soutěže.
2.2 Letová zóna
Letová zóna je prostor, kde jsou povolena přistání během soutěže. Modely přistávající mimo tuto zónu nelze během letu zvednout ani opět vzlétnout.
2.3 První pomoc
Na místě soutěže by měl být vyznačen bod první pomoci, kde bude k dispozici lékárnička.
3. Modely a vybavení podle tříd
3.1 Modely
Modely musí být vyrobeny z pěnových materiálů, například EPP, polystyrenu apod. Není povoleno používat tvrdé materiály k vyztužení náběžných hran křídel nebo stabilizátorů.
3.1.1 Třída RAPTUS
Rozpětí křídel: 600–700 mm
Délka: 600–700 mm
Motor: Elektrický, jeden motor
Baterie: 2–6S Li-po
Vrtule: 5–6 palců
Váha: do 1000g
Vybaven dvěma srtuhami o šířce 10mm a délce 2m
3.1.2 Třída WARBIRD
Rozpětí křídel: 800–1400 mm
Motor: Elektrický
Váha: Do 1800 g
3.3 Hlava a ochranné vybavení
Každý soutěžící a osoba v prostoru před diváky musí používat ochrannou helmu.
4. Soutěže
4.1 Struktura kol
Soutěž se skládá z několika kol, jejichž počet určuje organizátor. Doporučuje se 3–5 kol. Soutěž končí finálem, kterého se účastní čtyři piloti s nejvyšším počtem bodů.
4.2 Bodování
Úspěšný zásah: +5 bodů
Utržené poškození: -1 bod
4.3 Souboje
1 Úspěšný zásah = 5 bodů
1 Přijaté poškození = -1 bod
Souboj je chápán jako sportovní soutěž závodníků (pilotů) za použití jejich modelů. Každý souboj je rozdělen do tří částí: příprava, připravenost, let.
4.3.1 Příprava
Délku přípravného času určuje organizátor, doporučuje se pět minut. Hlavní rozhodčí signalizuje začátek přípravy na další souboj.
Během této části je možné provádět zkušební lety. 30 sekund před koncem přípravy hlavní rozhodčí oznámí „30 sekund do startu“ nebo „Připraveni“, což znamená čas na přípravu.
4.3.2 Připravenost
Připravenost nastává ihned po přípravné fázi a je oznámena hlavním rozhodčím. Během připravenosti by měli být všichni piloti a jejich pomocníci na linii připravenosti. Délka této fáze se liší podle rozhodnutí rozhodčího.
4.3.3 Let
Let začíná, když hlavní rozhodčí vydá dlouhý signál (píšťalka nebo slovní pokyn „start“). Piloti a jejich pomocníci mohou běžet ke svým modelům a vzlétnout. Let končí, když hlavní rozhodčí vydá další dlouhý signál. Piloti musí ukončit souboj a přistát, jakmile to uznají za vhodné. Po přistání posledního modelu může být vyhlášena další příprava.
4.3 Pozorovatelé
Každý hráč musí mít pozorovatele. Na linii pilotů smí být během letu pouze jeden pozorovatel a pilot na model (helma je povinná).
Pozorovatel musí být připraven pomoci v případě ztráty kontroly, přerušení videospojení nebo jiných technických problémů.
4.4 Start
Pomoc asistenta při startu modelu je povolena (hod rukou).
Po startu musí pilot přejít zpět na linii pilotů, aby neblokoval prostor ostatním soutěžícím.
Pokud model během startu převrátí kola, je možné jej znovu připravit ke vzletu, pouze pokud ostatní soutěžící již odstartovali.
Hlavní rozhodčí vydává signál ke startu – modely nesmí vzlétnout před tímto signálem (penalizace: nucené přistání a opětovný vzlet).
4.5 Doba letu
Signál „START“ také spouští časomíru (5 minut) a automaticky aktivuje „FPV Combat“ pro všechny hráče.
Pro třídu Basic Combat je možné použít připravené rampy (není povinné).
Rampy mají dvě kolejnice vzdálené 21 cm, délku 120 cm a sklon 30°.
Třída Open může vzlétnout dle svého uvážení.
Maximální doba letu je 5 minut = 300 s, model musí být schopen takto dlouhého letu.
4.6 Opětovný start v souboji
Maximální počet startů během letu není omezen. Pokud chce pilot znovu odstartovat model z prostoru pro odložené modely, musí mít svolení hlavního rozhodčího. Rozhodčí upozorní ostatní piloty na situaci. Opětovný start musí proběhnout z původního místa startu, tedy je nutný návrat na linii pilotů.
4.7 Změna modelu
Pro jeden souboj lze použít pouze jeden model. Nový model může být použit až v následujícím souboji.
4.8 Překročení bezpečnostní linie
Překročení bezpečnostní linie znamená překročení vymezené bezpečnostní zóny modelem ve vzduchu nebo při pohybu po zemi.
Za porušení dostane pilot penalizaci -25 bodů. Po druhém překročení musí okamžitě přistát a nemůže pokračovat v soutěži – dochází k diskvalifikaci.
4.9 Kolize
Za kolize ani ztrátu modelu nejsou udělovány trestné body.
4.10 Princip neúčasti (vyhýbání se souboji)
Pokud se pilot vyhýbá souboji déle než 30 sekund, hlavní rozhodčí ho napomene. Pokud pilot uvede technické problémy, musí okamžitě pokusit přistát v bezpečné zóně.
4.11 Remíza
Pokud mají piloti po finálním souboji stejný počet bodů, vítězí pilot, který získal více bodů právě ve finále.
Pokud jsou i tyto body stejné, vítězí pilot s nejvyšším počtem bodů během jednoho ze soubojů v dané soutěži.
4.12 Video frekvence / šířka pásma / výkon
Standardní video pásmo je Raceband a DJI.
Všichni uživatelé musí být schopni nastavit své vysílače v rozsahu Raceband nebo DJI.
Uživatelé DJI musí nastavit svůj systém na 25 MBIT.
Používané kanály:
Určené kanály budou zobrazeny na tabuli.
CH 1: RB-5658 MHz / DJI 5660 MHz
CH 3: RB-5732 MHz / DJI 5735 MHz
CH 5: RB-5806 MHz / DJI 5805 MHz
(nesmí být používán analogovými hráči)
CH 7: RB-5880 MHz / DJI 5914 MHz
Soutěžící musí být připraven změnit frekvenci svého video vysílače.
V případě kolize kanálů během finále musí hráč s nižším počtem bodů změnit frekvenci. Pro tuto změnu musí být poskytnut dodatečný čas. Přípravná doba na finální let nemůže začít, dokud není tato změna provedena. Soutěžící je zodpovědný za výběr kanálu tak, aby nedocházelo ke kolizím po změně.
50 bodů za zapnutí VTX během oficiálních letů.
25 bodů za špatný výběr VTX kanálu při přesunu do startovní oblasti.
4.13 Zhoršení podmínek / rušení / stížnost
Pokud se během soutěže zhorší počasí nebo si soutěžící stěžují na podmínky, organizátor by měl uspořádat hlasování mezi piloty. Většina rozhodne, zda soutěž odložit, zrušit, nebo jak naložit s dosavadními výsledky.
5. Rozhodčí
5.1 Hlavní rozhodčí
Hlavní rozhodčí odpovídá za kontrolu hmotnosti modelů a časomíru během kola. Je povinen sledovat celý let a v případě absence čárového rozhodčího kontrolovat bezpečnostní zónu.
Je také zodpovědný za udržení soutěžících před bezpečnostní linií během letu modelů.
Podvádění nebo pokus o podvod vede k diskvalifikaci soutěžícího. Rozhodnutí rozhodčího by mělo být založeno na hlasování ostatních hráčů.
5.2 Bezpečnostní rozhodčí
Bezpečnostní rozhodčí je primárně zodpovědný za bezpečnost na soutěži. Tento rozhodčí má vyšší pravomoc než hlavní rozhodčí, pokud jde o otázky bezpečnosti.
Bezpečnostní rozhodčí má upozorňovat na nebezpečí během letů. Měl by být umístěn tak, aby měl jasný přehled o překračování bezpečnostní linie. Je také zodpovědný za to, aby žádná osoba nebyla bez helmy mimo chráněnou zónu sítě nebo blíže k bezpečnostní linii, než je stanovená vzdálenost.
5.3 Rozhodčí pilota
Rozhodčí pilota zaznamenává body a dobu letu na kartu pilota.
Je také zodpovědný za:
Zaznamenání překročení bezpečnostní linie (ve spolupráci s bezpečnostním rozhodčím).
Určení neúčasti v souboji.
Určení přistání v přistávací oblasti pro modely.
Rozhodčí pilota je také zodpovědný za doručení karty soutěžícího hlavnímu rozhodčímu a za správné vyplnění a podpisy.
Byla uvolněna oficiální FPV Combat pravidla pro rok 2026, která se budou uplatňovat na oficiálních soutěžích. Originální znění pravidel v angličtině ke stažení zde: https://www.facebook.com/download/89322 ... ATIONS.pdf
Rychlý překlad pravidel do češtiny přes AI:
Pravidla soutěží a kategorií létajících modelů
1. Základy
Všechna pravidla EU pro UAV a jejich RC vybavení musí být dodržována s úpravami uvedenými v těchto pravidlech. Soutěžící je osobně odpovědný za model používaný v soutěži a za jakékoli osobní či materiální škody, které může způsobit. Je vyžadováno RC pojištění soutěžícího (na požádání musí být uvedeno číslo pojistky). Povinnost registrace pilota a modelu je závazná.
Organizátoři soutěže a hlavní rozhodčí jsou odpovědní za zajištění bezpečnosti soutěžících a diváků během soutěže, za dodržování ustanovení těchto pravidel, kontrolu frekvencí vysílačů během soutěže a za disciplínu a sportovní chování soutěžících.
1.2 Bezpečnost
Bezpečnost má vždy nejvyšší prioritu. Jakékoli chování nebo incident, který hlavní rozhodčí nebo organizátoři soutěže vyhodnotí jako nebezpečný, může vést k okamžité diskvalifikaci soutěžícího. Každý soutěžící může být požádán o provedení testovacího letu, aby prokázal, že je schopen bezpečně ovládat model vyrobený v souladu s národními předpisy.
2. Místo soutěže
Volba místa soutěže náleží organizátorovi. Doporučuje se, aby plocha určená pro soutěž nebyla menší než 200 × 100 m a aby letová oblast v okruhu od místa vzletu byla bez stromů nebo budov ve vzdálenosti větší než 100 m.
2.1 Zónování
Níže uvedený diagram ukazuje typické doporučené rozložení letové oblasti pro soutěž FPV combat. Bezpečnostní linie je hranicí letové oblasti, kterou model nesmí překročit, a slouží k udržení bezpečné vzdálenosti od pilotů a diváků.
Bezpečnostní linie je smluvní povahy a měla by být v prostoru soutěže označena červenobílou páskou. Ve vzdušném prostoru je chápána jako polorovina kolmící na letovou oblast.
Organizátor odpovídá za kontrolu bezpečnostní linie (letové zóny), která platí pro všechny piloty od zahájení až do konce soutěže. Organizátor by měl ponechat co největší vzdálenost mezi letovou oblastí a diváky.
Doporučené vzdálenosti:
bezpečnostní linie: 0 m
linie pilotů: 5 m
divácká zóna: 10–15 m
Pořadatel může provést změny podle místních podmínek a je jeho povinností informovat všechny účastníky.
2.2.1 Letová zóna
Letová zóna je vždy před bezpečnostní linií. V této oblasti jsou během boje povolena dočasná přistání. Její rozměry určuje organizátor podle místních podmínek. Model, který přistane mimo tuto zónu, nesmí být během boje nebo při letu jiných modelů vyzvednut. Pouze modely přistávající v této zóně mohou být během boje zvednuty a znovu odstartovat.
2.2.2 Přistávací plocha
Obdélníková plocha 50 × 40 m (počítáno od bezpečnostní linie) v letové zóně, označená organizátorem červenobílou páskou.
2.2.4 Bezpečnostní linie
Bezpečnostní linie vede paralelně s linií pilotů ve vzdálenosti 5 metrů. Model nesmí letět blíže k pilotům, než tato linie určuje. Jakýkoli model, který tuto linii překročí, podléhá penalizaci a pravidlům diskvalifikace. Toto platí po celou dobu soutěže pro všechny lety (bojové, testovací, demonstrační).
2.2.5 Linie pilotů + startovní boxy
Všichni piloti a jejich pomocníci musí startovat ze zadní strany této linie. Startovní boxy by měly poskytovat vzdálenost 3–5 metrů mezi piloty.
2.3 Diváci
Diváci musí být v bezpečné vzdálenosti, nejméně 10 m za bezpečnostní linií, nebo chráněni sítí. Oblast chráněná sítí je definována jako prostor od sítě do vzdálenosti rovné její výšce (např. síť 3 m = bezpečná zóna 3 m za ní).
2.4 První pomoc
Na místě soutěže musí být označené stanoviště první pomoci s lékárničkou dostupnou kdykoli.
3. Modely a vybavení podle kategorií
3.1 Model
Materiál modelu může být jakýkoli typ pěny: EPP, polystyren, styrodur, depron.
3.1.1 Model v kategorii RAPTUS
Odkaz: https://www.fpv-combat.com/download/raptus/
Jediným povoleným modelem je RaptuS (upravená verze původního návrhu Depa de Padova).
Rozpětí: 600–700 mm
Délka: 600–700 mm
Motor: elektrický
Li‑Po: 2–6S
Vrtule: 5–7"
Max. vzletová hmotnost: 1200 g
Přídavné vybavení: bez omezení
3.1.2 Model v kategorii WARBIRD
Jakýkoli maketový model vrtulového nebo proudového warbirdu (2. světová válka).
Hmotnost: do 2500 g (může upravit pořadatel)
Motor: elektrický
Li‑Po: 2–6S
Vrtule: libovolná
Rozpětí: 800–1400 mm
3.1.2 Model v kategorii WW1 BIPLANE
Jakýkoli maketový model dvouplošníku z 1. světové války.
Hmotnost: do 1200 g
Motor: elektrický 700–1100 kv
Li‑Po: 3S
Vrtule: 8–13"
Rozpětí: 1000–1200 mm
3.2 Instalace napájení
Model musí umožnit rychlé odpojení baterie od regulátoru bez použití nářadí. Každý soutěžící musí mít alespoň 2 baterie.
3.3 Ochrana hlavy
Každému účastníkovi a každé osobě před diváckou linií se doporučuje používat ochranu hlavy.
3.4 Rádio a FPV vybavení
Soutěžící musí před soutěží zkontrolovat dosah svého RC vybavení. Je odpovědný za jeho správnou funkci.
Aktivace VTX (analog i digitál) je zakázána během oficiálních letů pro piloty, kteří se neúčastní daného letu. Porušení: –50 bodů.
Organizátor poskytuje tabuli s frekvenčními tokeny. Pilot musí před zapnutím VTX vzít token a po letu jej vrátit.
Zapnutí VTX bez tokenu:
přestupek: –50 bodů
přestupek: veřejné házení shnilého ovoce + –100 bodů
Maximální výkon VTX musí odpovídat místním předpisům.
3.5 FPV Combat vybavení
Obecně:
životy, munice, rychlost střelby, úroveň obrany a síla střelby budou nastaveny pořadatelem na dálku pro každý zápas (výchozí hodnoty: 10 životů // 30 nábojů // obrana 3 // síla střelby 3 // rychlost střelby 3)
modul HC‑12 (433 MHz) musí být odnímatelný
propojení FPV‑Combat desky a HC‑12 modulu musí být provedeno pomocí servokonektoru (rozteč 2,54 mm)
Hardware & Firmware FPV‑Combat:
před soutěží musí být nainstalován nejnovější firmware
pozor: u desek verze 2.4/2.5 je nutná hardwarová úprava
Raptus Class:
max. 2 zbraně
2 senzory, jeden na každé koncové části křídla, směřující ven dle aktuálních plánů stavby
telemetrický modul 433 MHz HC‑12
Combat Board musí být přístupná pro kontrolu
Warbird Class:
max. 2 zbraně
2 senzory umístěné tak, aby poskytovaly maximální pokrytí (kontroluje rozhodčí)
WW1 Biplane Class:
4. Soutěže
4.1 Struktura kola
Kolo je provedení přesně jednoho boje každým pilotem. Počet kol musí být určen před soutěží. Doporučuje se 4–6 kol.
Soutěž končí finále, které následuje po odehrání všech kol. Do finále postupují piloti s nejvyšším počtem bodů. Vítězem soutěže se stává pilot s nejvyšším součtem bodů ze všech kol a finále.
4.2 Bodování
1 úspěšný zásah jiného letadla = +3 body
1 úspěšný zásah statického cíle = +2 body
1 obdržené poškození = –1 bod
4.3 Boje
Boj je sportovní soutěž pilotů s jejich modely. Každý boj má tři části: příprava, připravenost, let.
4.3.1 Příprava
Doporučená délka přípravy je 5 minut. Zahajuje ji hlavní rozhodčí.
4.3.2 Připravenost
Začíná ihned po přípravě. Všichni piloti a jejich pomocníci musí být na linii připravenosti. Doba trvání závisí na rozhodčím.
Je nutné mít systém, který udrží VTX v chladu během několika minut čekání.
4.3.3 Let
Letová část začíná dlouhým signálem (píšťalka nebo „START“). Piloti mohou běžet ke svým modelům a odstartovat.
Vzlet je povolen až po skončení odpočítávání a zaznění signálu.
Letová část končí dalším dlouhým signálem. Piloti musí ukončit boj a přistát, jakmile to uznají za bezpečné. Po přistání posledního modelu může být vyhlášena další příprava.
4.3 Pozorovatelé
Každý pilot musí mít pozorovatele. V linii pilotů může být pouze pilot a jeden pozorovatel.
Pozorovatel pomáhá při:
ztrátě kontroly
ztrátě videa
technických problémech
taktických radách
4.4 Start
Pomocník může pomoci se startem (hodem z ruky). Po startu se pilot musí vrátit na linii pilotů.
Pokud model převrátí při startu z podvozku, může být znovu postaven až po odstartování ostatních pilotů.
Start před signálem = povinné přistání a nový start.
4.5 Doba letu
bojový čas: 4 minuty
maximální letový čas: 5 minut (300 s) Model musí být schopen této doby letu.
4.6 Restart během boje
Počet restartů není omezen. Pilot musí mít povolení rozhodčího k vyzvednutí modelu z letové zóny. Restart musí být proveden z původního místa startu.
4.7 Změna modelu
V jednom boji lze použít pouze jeden model. Nový model lze použít až v dalším boji.
4.8 Přistání
Přistání v určené přistávací zóně = +5 bodů.
4.9 Kolize
Za kolize nebo ztrátu modelu nejsou žádné penalizace.
4.10 Princip neúčasti (vyhýbání se boji)
Pokud pilot zůstane mimo boj déle než 30 sekund, musí být varován. Pokud oznámí technické problémy, musí okamžitě bezpečně přistát.
4.11 Remíza
Při rovnosti bodů po finále vyhrává pilot s více body ve finále. Pokud jsou i tyto body stejné, rozhoduje nejlepší výsledek z kteréhokoli boje v soutěži.
Standardní videopásma: Raceband a DJI DJI musí být nastaveno na 25 Mbit.
Používané kanály:
CH1: RB 5658 MHz / DJI 5660 MHz
CH3: RB 5732 MHz / DJI 5735 MHz
CH5: RB 5806 MHz / DJI 5805 MHz (analog nesmí používat)
CH7: RB 5880 MHz / DJI 5914 MHz
Pilot musí být připraven změnit kanál.
Při kolizi kanálů ve finále mění kanál pilot s méně body.
Zapnutí VTX během oficiálního letu = –50 bodů.
4.13 Zhoršení podmínek / stížnosti
Pokud se zhorší počasí nebo podmínky, organizátor musí vyhlásit hlasování pilotů o:
odložení soutěže
zrušení soutěže
způsobu započítání výsledků
5. Rozhodčí
5.1 Hlavní rozhodčí
Odpovídá za:
časomíru
sledování celého boje
kontrolu bezpečnostní zóny (pokud není přítomen bezpečnostní rozhodčí)
udržování pilotů před bezpečnostní linií
Podvod nebo pokus o podvod = diskvalifikace. Rozhodnutí rozhodčího má být podpořeno hlasem ostatních pilotů.
Má vyšší pravomoc než hlavní rozhodčí v otázkách bezpečnosti.
Je odpovědný za:
varování před nebezpečnými situacemi
sledování překročení bezpečnostní linie
kontrolu, že nikdo bez helmy není v nechráněné zóně
5.3 Pozorovatel pilota
Pomáhá pilotovi při startu a při hledání modelu po havarijním přistání.
Return to “FPV Air Combat”
