Prodám triversity FPV přijímač FXT FX888R FPV
Máte doma něco, co se plete v šuplíku a chcete to předat dál buď výměnou za peníze či jiný produkt? Zde je to správné místo.
Forum rules
Has thanked: 1149 times
Been thanked: 372 times
Prodám nepoužívaný triversity FPV přijímač FXT FX888R FPV
FPV přijímač je vhodný například pro použití v Ground Stationu. Důvod prodeje - přecházím na digitální FPV, tak se zbavuji analogového vybavení. Kupovaný byl zde: https://www.aliexpress.com/i/32947884126.html
Podrobnější info v diskusi zde: https://www.rcgroups.com/forums/showthr ... Or-3xRC832
FXT FX888R FPV RX Receiver 5.8G 6 Bands 48CH Raceband Triversity Receiver Built-in 128*64 OLED Cover Channels for RC Drone. Triple the receivers all packed in 1 ground station receiving unit for the 5.8GHz . With 3 active receivers you can easily mix and match a variety of antennas to maximize your FPV signal coverage. Use 3 directional antennas for high gain (long range) and wide fov reception. Or mix some directional and omni-directional antennas for the perfect all around reception.
Specification:
Input voltage: 7-28v
Current consumption: MAX330mA@12v
Antenna connector: SMA
AV out: earphone 2.5mm
OLED resolution: 128*64 pixels
Channels: 6 s 48 channels
Frequency range: 5300-6000MHz
Dimension: 110x100x20mm
Weight: 97g(excludes antennas)
Features:
1.Built-in "3" receivers(patent pending),the three independent receivers can be turned on or turned off,it automatically receive best signal
2. Built-in OLED real-time display input voltage,signal strength and working channel
3.Easy to use buttons with channel autoscan
4.With 4AV output port,support mutiple AV OUT
5.Built-in tripod nut for easy installation on tripod
6.Power by 2s-6s battery
7. Plug and play
8. Three independent receivers can be turned on or turned OFF
9. s 48 channels with race
10. Three SMA antenna connectors
Package included:
1x FXT 5.8GHz 48CH Triversity Receiver
3x Antennas
1x RCA audio/video cable
1x XT60 power-in cable
1x User Manual
Cena: 990kč, nabídky prosím do SZ.
Image Image Image
Re: Prodám triversity FPV přijímač FXT FX888R FPV
Snížení ceny na 800kč
Return to “Prodám či vyměním”
